주요 콘텐츠로 건너뛰기
Black and Decker BDEDMT Motor Replacement
필요한 것
  1. Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: 1 단계, 이미지 1/2 Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: 1 단계, 이미지 2/2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: 2 단계, 이미지 1/3 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: 2 단계, 이미지 2/3 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: 2 단계, 이미지 3/3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Motor Replacement, Motor: 3 단계, 이미지 1/1
    • Gently pull up the motor and other components at the top of the device except the handle.
    • Watch out for the wires. They are connected to two compressed magnets in the black framework.
  4. Black and Decker BDEDMT Motor Replacement: 4 단계, 이미지 1/2 Black and Decker BDEDMT Motor Replacement: 4 단계, 이미지 2/2
    • Slide off the the black framework on the barring side.
    • You may have to compress the magnets in order to slide the framework off of the barring.
  5. Black and Decker BDEDMT Motor Replacement: 5 단계, 이미지 1/2 Black and Decker BDEDMT Motor Replacement: 5 단계, 이미지 2/2
    • Remove the release button attached at the front of the motor.
    • It may have already come off during Step 3.
  6. Black and Decker BDEDMT Motor Replacement: 6 단계, 이미지 1/2 Black and Decker BDEDMT Motor Replacement: 6 단계, 이미지 2/2
    • Work the silver magnetic ring off of the motor through the barring end.
    • The motor is now free.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler Yurina
회원 가입일: 02/01/16
419 평판
안내서 2개 작성하였습니다
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016 회원
UWT-ROSE-W16S1G2
4 회원들
안내서 11개 작성하였습니다
댓글 3개
Hi,
Please can you tell me where to find the motor replacement part for this tool?
Thank you
Renato - 답글
I have this tool and the attachments and I absolutely love it…but I'm pretty sure the gears are stripped…do you know anything about replacing those?
cwilson0713@gmail.com - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 61
전체 시간: 2,652
