주요 콘텐츠로 건너뛰기
Black and Decker BDEDMT Power Cord Replacement
필요한 것
  1. Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: 1 단계, 이미지 1/2 Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: 1 단계, 이미지 2/2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: 2 단계, 이미지 1/3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: 2 단계, 이미지 2/3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: 2 단계, 이미지 3/3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: 3 단계, 이미지 1/2 Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: 3 단계, 이미지 2/2
    • Using the T-handle screwdriver with the JIS 1 bit, unscrew the two lower black 12mm screws.
  4. Black and Decker BDEDMT Power Cord Replacement: 4 단계, 이미지 1/2 Black and Decker BDEDMT Power Cord Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  5. Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: 5 단계, 이미지 1/2 Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: 5 단계, 이미지 2/2
    • Physically pull up on the trigger device and remove it from the armature.
    • Flip trigger device over onto its back.
  6. Black and Decker BDEDMT Power Cord Replacement, Wire Removal: 6 단계, 이미지 1/3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: 6 단계, 이미지 2/3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: 6 단계, 이미지 3/3
    • There is a screw labeled 3 located on the bottom left of the back of the trigger device.
    • Use a JIS 0 screwdriver to remove screw.
    • Gently tug on the black wire to pull the wire out of the device.
    • Now the power cord will be completely removed from the device.
결론
cayla dahl
회원 가입일: 02/01/16
247 평판
안내서 2개 작성하였습니다
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016 회원
UWT-ROSE-W16S1G2
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 32
전체 시간: 2,077
