주요 콘텐츠로 건너뛰기
Black and Decker BDERO100 Power Cord Replacement
필요한 것
  1. Black and Decker BDERO100 Power Cord Replacement, Chassis: 1 단계, 이미지 1/2 Black and Decker BDERO100 Power Cord Replacement, Chassis: 1 단계, 이미지 2/2
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Power Cord Replacement: 2 단계, 이미지 1/2 Black and Decker BDERO100 Power Cord Replacement: 2 단계, 이미지 2/2
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Power Cord Replacement: 3 단계, 이미지 1/2 Black and Decker BDERO100 Power Cord Replacement: 3 단계, 이미지 2/2
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Power Cord Replacement: 4 단계, 이미지 1/2 Black and Decker BDERO100 Power Cord Replacement: 4 단계, 이미지 2/2
    • Hold the chassis and separate it from the device.
  5. Black and Decker BDERO100 Power Cord Replacement, Power Cord: 5 단계, 이미지 1/3 Black and Decker BDERO100 Power Cord Replacement, Power Cord: 5 단계, 이미지 2/3 Black and Decker BDERO100 Power Cord Replacement, Power Cord: 5 단계, 이미지 3/3
    • Use the bit driver with the JIS - J1 bit to remove the two 12.5 mm phillips screws holding the cord clamp to the chassis.
  6. Black and Decker BDERO100 Power Cord Replacement: 6 단계, 이미지 1/3 Black and Decker BDERO100 Power Cord Replacement: 6 단계, 이미지 2/3 Black and Decker BDERO100 Power Cord Replacement: 6 단계, 이미지 3/3
    • Gently pull the white cable that connects the power cord to the motor to detach it.
  7. Black and Decker BDERO100 Power Cord Replacement: 7 단계, 이미지 1/2 Black and Decker BDERO100 Power Cord Replacement: 7 단계, 이미지 2/2
    • With yout hands, hold and separate the power button from the external case by pulling gently.
  8. Black and Decker BDERO100 Power Cord Replacement: 8 단계, 이미지 1/2 Black and Decker BDERO100 Power Cord Replacement: 8 단계, 이미지 2/2
    • Select the cable that connects the power button to the power button.
  9. Black and Decker BDERO100 Power Cord Replacement: 9 단계, 이미지 1/1
    • Expose the cable and lock system by removing the cover.
    • When attaching the new power cord you will need to make sure to cover this lock system with electrical tape.
  10. Black and Decker BDERO100 Power Cord Replacement: 10 단계, 이미지 1/2 Black and Decker BDERO100 Power Cord Replacement: 10 단계, 이미지 2/2
    • Push the security pin with the plastic spudger and simultaneously, pull gently on the cable to separate it from the button.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Irene Zubillaga
회원 가입일: 02/10/16
617 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-5, Sullivan Spring 2016 USF Tampa, Team 1-5, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 623
