주요 콘텐츠로 건너뛰기
Black and Decker BDH9600CHV Filter Button Replacement
필요한 것
  1. Black and Decker BDH9600CHV Filter Button Replacement, Filter Button: 1 단계, 이미지 1/3 Black and Decker BDH9600CHV Filter Button Replacement, Filter Button: 1 단계, 이미지 2/3 Black and Decker BDH9600CHV Filter Button Replacement, Filter Button: 1 단계, 이미지 3/3
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Filter Button Replacement: 2 단계, 이미지 1/1
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Filter Button Replacement: 3 단계, 이미지 1/2 Black and Decker BDH9600CHV Filter Button Replacement: 3 단계, 이미지 2/2
    • Pull the housing apart.
    • Note when the housing is taken apart some parts may fall out be sure to keep track of any parts that come out.
    • Remove the filter button by pulling it out.
  4. Black and Decker BDH9600CHV Filter Button Replacement: 4 단계, 이미지 1/1
    • Replace the new button by compressing the spring and placing it in the groove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ivette Muzquiz
회원 가입일: 11/06/17
349 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G4, Harley Fall 2017 IUPUI, Team S1-G4, Harley Fall 2017 회원
IUPUI-HARLEY-F17S1G4
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
After a year of very light use, it was working great. Now I have been facing some troublesome it’s shutting down frequently as like after about a minute. I bought a new filter and it is still shut down. Kept on the charger all the time. Do you have any idea actually what is going wrong with it? Or do you have any suggestion which would be best for pet hair?
Alexis Martinovich - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 13
전체 시간: 553
