주요 콘텐츠로 건너뛰기
Black and Decker BDH9600CHV Motor Replacement
필요한 것
  1. Black and Decker BDH9600CHV Motor Replacement, Motor: 1 단계, 이미지 1/3 Black and Decker BDH9600CHV Motor Replacement, Motor: 1 단계, 이미지 2/3 Black and Decker BDH9600CHV Motor Replacement, Motor: 1 단계, 이미지 3/3
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Motor Replacement: 2 단계, 이미지 1/1
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Motor Replacement: 3 단계, 이미지 1/3 Black and Decker BDH9600CHV Motor Replacement: 3 단계, 이미지 2/3 Black and Decker BDH9600CHV Motor Replacement: 3 단계, 이미지 3/3
    • Pull the housing apart
    • When you pull apart the housing pieces could fall out. Be sure to keep track of them.
    • Remove the motor unit from the housing
    • Note that the black disk needs to be firmly pulled it will resist, but can be pulled directly off of the pin if it is pulled hard enough.
  4. Black and Decker BDH9600CHV Motor Replacement: 4 단계, 이미지 1/3 Black and Decker BDH9600CHV Motor Replacement: 4 단계, 이미지 2/3 Black and Decker BDH9600CHV Motor Replacement: 4 단계, 이미지 3/3
    • Remove the motor from the circuit board.
    • The motor makes contact with the board at 2 points. These may be bent or distorted. Straighten them with a pair of needle nose pliers in order to remove.
결론
Ivette Muzquiz
회원 가입일: 11/06/17
349 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G4, Harley Fall 2017 IUPUI, Team S1-G4, Harley Fall 2017 회원
IUPUI-HARLEY-F17S1G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 15
전체 시간: 2,309
