주요 콘텐츠로 건너뛰기
Black and Decker BDH9600CHV Power Switch Replacement
필요한 것
  1. Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: 1 단계, 이미지 1/3 Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: 1 단계, 이미지 2/3 Black and Decker BDH9600CHV Power Switch Replacement, Power Switch: 1 단계, 이미지 3/3
    • To remove the filter and housing, press the green button labeled "Filter".
  2. Black and Decker BDH9600CHV Power Switch Replacement: 2 단계, 이미지 1/1
    • Unscrew and remove all 5 screws using the Phillips 0 screw bit. Each screw is 17.5 mm long.
  3. Black and Decker BDH9600CHV Power Switch Replacement: 3 단계, 이미지 1/2 Black and Decker BDH9600CHV Power Switch Replacement: 3 단계, 이미지 2/2
    • Pull the housing apart.
    • When you pull the housing apart, pieces may fall out. Be sure to track of the parts and where they go.
    • Remove the switch by pulling it out.
  4. Black and Decker BDH9600CHV Power Switch Replacement: 4 단계, 이미지 1/2 Black and Decker BDH9600CHV Power Switch Replacement: 4 단계, 이미지 2/2
    • Replace the new switch by sliding the replacement switch onto the top of the switch mechanism located on the motor.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ivette Muzquiz
회원 가입일: 11/06/17
349 평판
안내서 3개 작성하였습니다
IUPUI, Team S1-G4, Harley Fall 2017 IUPUI, Team S1-G4, Harley Fall 2017 회원
IUPUI-HARLEY-F17S1G4
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
My switch with up & down button box like
Fernando Palacios - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 14
전체 시간: 1,130
