주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This installation guide will help you separate the blades from the blender jar. Once separated, you can successfully install replacements blades or to check for any malfunctions with the blades.
  1. Make sure the blender is turned off and unplugged from all power.
    • Make sure the blender is turned off and unplugged from all power.
    • Remove the glass jar from the base of the blender.
  2. Remove the top lid from the blender jar.
    • Remove the top lid from the blender jar.
  3. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Twist the plastic base of the jar counterclockwise to remove it from the glass upper half.
    • Twist the plastic base of the jar counterclockwise to remove it from the glass upper half.
    • Take care not to cut yourself on the blades.
  5. Lift the rubber washer straight up to remove it from the blade assembly.
    • Lift the rubber washer straight up to remove it from the blade assembly.
  6. Lift the blades from the bottom cap.
    • Lift the blades from the bottom cap.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew
회원 가입일: 2012년 10월 04일
170 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 회원
CPSU-REGAN-F12S6G34
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 73
전체 시간: 3,826
