주요 콘텐츠로 건너뛰기
Black and Decker BL3000S Motor Fan Replacement
필요한 것
  1. Black and Decker BL3000S Motor Fan Replacement, Blender Base: 1 단계, 이미지 1/2 Black and Decker BL3000S Motor Fan Replacement, Blender Base: 1 단계, 이미지 2/2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S Motor Fan Replacement: 2 단계, 이미지 1/1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S Motor Fan Replacement: 3 단계, 이미지 1/2 Black and Decker BL3000S Motor Fan Replacement: 3 단계, 이미지 2/2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S Motor Fan Replacement: 4 단계, 이미지 1/1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S Motor Fan Replacement: 5 단계, 이미지 1/1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S Motor Fan Replacement, Motor Fan: 6 단계, 이미지 1/2 Black and Decker BL3000S Motor Fan Replacement, Motor Fan: 6 단계, 이미지 2/2
    • Using pliers, remove the top nut from the fan and remove the washer.
    • Use a small towel to hold the fan in place. This makes taking off the nut easier to do.
  7. Black and Decker BL3000S Motor Fan Replacement: 7 단계, 이미지 1/1
    • Lift the fan blades from the blender base.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Andrew
회원 가입일: 10/04/12
209 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 회원
CPSU-REGAN-F12S6G34
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
mon mixeur a montre des itincelles et de la fumeé quel étape puis suivre pour le réparer
abdelkarim hassi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 43
전체 시간: 4,423
