주요 콘텐츠로 건너뛰기
Black and Decker BL3000S button panel replacement
필요한 것
  1. Black and Decker BL3000S button panel replacement, Blender Base: 1 단계, 이미지 1/2 Black and Decker BL3000S button panel replacement, Blender Base: 1 단계, 이미지 2/2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S button panel replacement: 2 단계, 이미지 1/1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S button panel replacement: 3 단계, 이미지 1/2 Black and Decker BL3000S button panel replacement: 3 단계, 이미지 2/2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S button panel replacement: 4 단계, 이미지 1/1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S button panel replacement: 5 단계, 이미지 1/1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S button panel replacement, Circuit Board: 6 단계, 이미지 1/1
    • Once you have the base removed, the circuit board should be clearly visible inside.
  7. Black and Decker BL3000S button panel replacement: 7 단계, 이미지 1/2 Black and Decker BL3000S button panel replacement: 7 단계, 이미지 2/2
    • Remove the four screws located on the circuit board.
    • Two are on the left side.
    • Two are on the right side.
  8. Black and Decker BL3000S button panel replacement: 8 단계, 이미지 1/1
    • Remove the following soldered connections with a soldering iron:
    • Motor wires
    • Power cord wires
  9. Black and Decker BL3000S button panel replacement: 9 단계, 이미지 1/1
    • Lift the circuit board straight up to remove it from the base.
  10. Black and Decker BL3000S button panel replacement, Buttons: 10 단계, 이미지 1/1
    • Once the circuit board has been freed from its screws it can be moved out of the way to gain access to the buttons.
    • A single screw must be removed from the top as shown.
  11. Black and Decker BL3000S button panel replacement: 11 단계, 이미지 1/1
    • Push firmly from the outside of the blender on the face of the buttons to pop it out of its locked position.
  12. Black and Decker BL3000S button panel replacement: 12 단계, 이미지 1/2 Black and Decker BL3000S button panel replacement: 12 단계, 이미지 2/2
    • Provided is a front and a back view of a functioning button frame from the BL3000S.
    • Check for cracks, bends, debris, or missing extentions and fastens.
결론
Austin Abernathy
회원 가입일: 10/05/12
18 평판
안내서 1개 작성함
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 회원
CPSU-REGAN-F12S6G34
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 2,378
