이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
You will need to have completed the prerequisite guides prior to this guide in order to execute it.
필요한 것
Once you have the base removed, the circuit board should be clearly visible inside.
Once the circuit board has been freed from its screws it can be moved out of the way to gain access to the buttons.
A single screw must be removed from the top as shown.
거의 끝나갑니다!
결론
