주요 콘텐츠로 건너뛰기
Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement
필요한 것
  1. Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement, Clamshell (Black Outer Casing): 1 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement: 2 단계, 이미지 1/2 Black and Decker BV2500 Type 4 Clamshell (Black Outer Casing) Replacement: 2 단계, 이미지 2/2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
결론
Angelica Chow
회원 가입일: 01/25/14
409 평판
안내서 3개 작성하였습니다
Cal Poly, Team 9-29, Maness Winter 2014 Cal Poly, Team 9-29, Maness Winter 2014 회원
CPSU-MANESS-W14S9G29
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 746
