주요 콘텐츠로 건너뛰기
Black and Decker BV2500 Type 4 Power Cord Replacement
필요한 것
  1. Black and Decker BV2500 Type 4 Power Cord Replacement, Clamshell (Black Outer Casing): 1 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Power Cord Replacement: 2 단계, 이미지 1/2 Black and Decker BV2500 Type 4 Power Cord Replacement: 2 단계, 이미지 2/2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Power Cord Replacement, Power Cord: 3 단계, 이미지 1/2 Black and Decker BV2500 Type 4 Power Cord Replacement, Power Cord: 3 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the ten 20 mm screws in the orange casing.
    • Use your hands to lift off the side of the orange casing with the screws facing you.
  4. Black and Decker BV2500 Type 4 Power Cord Replacement: 4 단계, 이미지 1/2 Black and Decker BV2500 Type 4 Power Cord Replacement: 4 단계, 이미지 2/2
    • Locate the switch.
    • Remove the 2 black and white wires with blue casings from the switch.
    • Using your hands, push in the sides of the switch and slide out the wires.
  5. Black and Decker BV2500 Type 4 Power Cord Replacement: 5 단계, 이미지 1/1
    • Remove the two 20 mm Phillips #2 screws that are holding in the power cord (located at the bottom of the leaf hog).
  6. Black and Decker BV2500 Type 4 Power Cord Replacement: 6 단계, 이미지 1/3 Black and Decker BV2500 Type 4 Power Cord Replacement: 6 단계, 이미지 2/3 Black and Decker BV2500 Type 4 Power Cord Replacement: 6 단계, 이미지 3/3
    • Slide the power cord support off the power cord in the direction of the leads.
    • Use your hands to pull the power cord out of the device with the lead end coming out last.
결론
Angelica Chow
회원 가입일: 01/25/14
409 평판
안내서 3개 작성하였습니다
Cal Poly, Team 9-29, Maness Winter 2014 Cal Poly, Team 9-29, Maness Winter 2014 회원
CPSU-MANESS-W14S9G29
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 3,628
