주요 콘텐츠로 건너뛰기
Black and Decker BV2500 Type 4 Powerhead Assembly Replacement
필요한 것
  1. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement, Clamshell (Black Outer Casing): 1 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement: 2 단계, 이미지 1/2 Black and Decker BV2500 Type 4 Powerhead Assembly Replacement: 2 단계, 이미지 2/2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement, Powerhead Assembly: 3 단계, 이미지 1/1
    • The powerhead assembly is the entire orange part of the device.
    • Replace it with a new powerhead assembly.
결론
Angelica Chow
회원 가입일: 01/25/14
409 평판
안내서 3개 작성하였습니다
Cal Poly, Team 9-29, Maness Winter 2014 Cal Poly, Team 9-29, Maness Winter 2014 회원
CPSU-MANESS-W14S9G29
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,184
