주요 콘텐츠로 건너뛰기
Black and Decker Dustbuster CHV1510 Motor Replacement
필요한 것
  1. Black and Decker Dustbuster CHV1510 Motor Replacement, Prerequisite Only Guide: 1 단계, 이미지 1/1
    • Press the buttons with unlock symbols on both sides of the nozzle.
    • Pull the nozzle upward.
    • The other button cannot be seen on the image.
  2. Black and Decker Dustbuster CHV1510 Motor Replacement: 2 단계, 이미지 1/1
    • Press the button with the "Filter" indicator.
    • Pull the filter cover upward.
  3. Black and Decker Dustbuster CHV1510 Motor Replacement: 3 단계, 이미지 1/1
    • Hold the vacuum base firmly and remove all six exterior 20 mm Phillips #0 screws.
  4. Black and Decker Dustbuster CHV1510 Motor Replacement: 4 단계, 이미지 1/3 Black and Decker Dustbuster CHV1510 Motor Replacement: 4 단계, 이미지 2/3 Black and Decker Dustbuster CHV1510 Motor Replacement: 4 단계, 이미지 3/3
    • Carefully and gently pull the two halves of the vacuum apart.
  5. Black and Decker Dustbuster CHV1510 Motor Replacement, Electric Motor: 5 단계, 이미지 1/2 Black and Decker Dustbuster CHV1510 Motor Replacement, Electric Motor: 5 단계, 이미지 2/2
    • Pull out the motor section from the vacuum.
  6. Black and Decker Dustbuster CHV1510 Motor Replacement: 6 단계, 이미지 1/3 Black and Decker Dustbuster CHV1510 Motor Replacement: 6 단계, 이미지 2/3 Black and Decker Dustbuster CHV1510 Motor Replacement: 6 단계, 이미지 3/3
    • Use an opening tool to lift the plastic strips underneath the motor upwards to separate them from the motor cover.
    • The other plastic strip cannot be seen on the image.
    • Be cautious, as removing the two plastic strips can take a bit of force.
  7. Black and Decker Dustbuster CHV1510 Motor Replacement: 7 단계, 이미지 1/3 Black and Decker Dustbuster CHV1510 Motor Replacement: 7 단계, 이미지 2/3 Black and Decker Dustbuster CHV1510 Motor Replacement: 7 단계, 이미지 3/3
    • Disconnect the two red and black wires from the motor.
    • Ensure that all disconnected wires can be distinguished from one another to avoid confusion when reassembling your device.
  8. Black and Decker Dustbuster CHV1510 Motor Replacement: 8 단계, 이미지 1/3 Black and Decker Dustbuster CHV1510 Motor Replacement: 8 단계, 이미지 2/3 Black and Decker Dustbuster CHV1510 Motor Replacement: 8 단계, 이미지 3/3
    • Use an opening tool to pull off the black fan underneath the motor.
    • Be cautious, as removing this fan can take a bit of force.
  9. Black and Decker Dustbuster CHV1510 Motor Replacement: 9 단계, 이미지 1/2 Black and Decker Dustbuster CHV1510 Motor Replacement: 9 단계, 이미지 2/2
    • Unscrew the two 10 mm Phillips #1 screws underneath the motor.
  10. Black and Decker Dustbuster CHV1510 Motor Replacement: 10 단계, 이미지 1/1
    • Replace old motor with replacement motor.
결론
To reassemble your device, follow these instructions in reverse order. When reconnecting the wires, ensure you reattach each wire at the correct points to avoid confusion later.
다른 4명이 해당 안내서를 완성하였습니다.
Dominic Krier
회원 가입일: 05/17/22
225 평판
안내서 1개 작성함
댓글 3개
We’re do I purchase a replacement motor. My Black & Decker Dustbuster is model CHV1510. The bad motor is labeled N543847, RS545M5517F, DC 14.4V, KPVN21314N.
climba14er - 답글
Hi
May you help me?
I have a black&decker dustbuster cordless....and the batteries are dead and I want to run it directly by adapter. It has a johnson 14.4v dc motor and i cant find its datasheet to choose the best adapter.now for this motor what is your suggestion?
As you know better than me,adapters arent made in all voltages.
15v-5A?
16.5v-4.7A(my laptop adapter)?
please give some options for voltage and amperage so i can buy adapter (or make by adding three 6A-diods to my laptop adapter and achieve to for example 16.5v 4.7A )
Thanks
m m - 답글
Excellent guide!
I didn't need to replace the motor, but I did need to get to the motor to remove some hair and other string-like things from the shaft.
Additionally, I needed to remove the impeller to clean it out (it was caked with dirt - apparently the primary cause for the issue I was having (very loud - but not squeaking, little suction). If you've already taken the unit apart this far, it's worth it to remove the impeller and give it a good cleaning - gunk can get stuck inside the impeller reducing the openings in the airflow channels.
Keith Kyzivat (Keithel) - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 76
전체 시간: 2,043
