주요 콘텐츠로 건너뛰기
Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal Replacement
필요한 것
  1. Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement, Vacuum Rubber Seal: 1 단계, 이미지 1/1
    • Press the grey buttons with the unlock symbols on both sides of the nozzle.
    • Pull the nozzle upwards.
    • The other button cannot be seen on the image.
  2. Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: 2 단계, 이미지 1/3 Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: 2 단계, 이미지 2/3 Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool to pry the clear rubber seal away from the white plastic nozzle.
  3. Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: 3 단계, 이미지 1/1
    • Remove the clear seal from the nozzle.
    • If the nozzle does not connect to vacuum barrel while reassembling, readjust the rubber seal and try to attach the nozzle until the two snap into place.
결론
To reassemble your device, follow these instructions in reverse order. While reassembling, if the nozzle does not connect to vacuum barrel, readjust the rubber seal and try to attach the nozzle until the two snap into place.
다른 2명이 해당 안내서를 완성하였습니다.
Kristopher Darrin
회원 가입일: 05/17/22
124 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 9
30일 전: 16
전체 시간: 369
