주요 콘텐츠로 건너뛰기
Black and Decker G48TD Disassembly
필요한 것
  1. Black and Decker G48TD Disassembly, Black and Decker G48TD Disassembly: 1 단계, 이미지 1/2 Black and Decker G48TD Disassembly, Black and Decker G48TD Disassembly: 1 단계, 이미지 2/2
    • Open the grill.
  2. Black and Decker G48TD Disassembly: 2 단계, 이미지 1/3 Black and Decker G48TD Disassembly: 2 단계, 이미지 2/3 Black and Decker G48TD Disassembly: 2 단계, 이미지 3/3
    • Remove the top and bottom griddle plates.
  3. Black and Decker G48TD Disassembly: 3 단계, 이미지 1/3 Black and Decker G48TD Disassembly: 3 단계, 이미지 2/3 Black and Decker G48TD Disassembly: 3 단계, 이미지 3/3
    • Use a pair of Large Needle Nosed Pliers to twist the metal tabs holding the plate housing the bottom heating element connections and remove the plate.
  4. Black and Decker G48TD Disassembly: 4 단계, 이미지 1/3 Black and Decker G48TD Disassembly: 4 단계, 이미지 2/3 Black and Decker G48TD Disassembly: 4 단계, 이미지 3/3
    • Use a pair of Large Needle Nosed Pliers to twist the metal tabs holding the plate housing the top heating element connections and remove the plates.
  5. Black and Decker G48TD Disassembly: 5 단계, 이미지 1/3 Black and Decker G48TD Disassembly: 5 단계, 이미지 2/3 Black and Decker G48TD Disassembly: 5 단계, 이미지 3/3
    • Use pliers to twist the metal tabs holding down the thermostat housing.
  6. Black and Decker G48TD Disassembly: 6 단계, 이미지 1/2 Black and Decker G48TD Disassembly: 6 단계, 이미지 2/2
    • Use a 4 mm Flathead screwdriver to remove the 11.4 mm screw in the back of the thermostat housing.
  7. Black and Decker G48TD Disassembly: 7 단계, 이미지 1/2 Black and Decker G48TD Disassembly: 7 단계, 이미지 2/2
    • Lift up the thermostat housing and detach it from the temperature control arm, then remove the washers at the end of the temperature control arm.
  8. Black and Decker G48TD Disassembly: 8 단계, 이미지 1/2 Black and Decker G48TD Disassembly: 8 단계, 이미지 2/2
    • Remove the thermostat housing.
  9. Black and Decker G48TD Disassembly: 9 단계, 이미지 1/2 Black and Decker G48TD Disassembly: 9 단계, 이미지 2/2
    • Remove the thermostat housing springs.
  10. Black and Decker G48TD Disassembly: 10 단계, 이미지 1/2 Black and Decker G48TD Disassembly: 10 단계, 이미지 2/2
    • Bend up the brackets holding down the heating elements.
  11. Black and Decker G48TD Disassembly: 11 단계, 이미지 1/2 Black and Decker G48TD Disassembly: 11 단계, 이미지 2/2
    • Remove the heating elements from their respective housings (the bottom one is not able to be removed completely as it is fused to a piece of metal).
  12. Black and Decker G48TD Disassembly: 12 단계, 이미지 1/2 Black and Decker G48TD Disassembly: 12 단계, 이미지 2/2
    • Remove the housing from the wiring along the bottom of the grill.
  13. Black and Decker G48TD Disassembly: 13 단계, 이미지 1/1
    • The device is fully disassembled!
결론
Connor White
회원 가입일: 09/16/21
267 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 19
전체 시간: 406
