주요 콘텐츠로 건너뛰기
Black and Decker JE2200B Disassembly
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
  1. Black and Decker JE2200B Disassembly, Unlocking Latches: 1 단계, 이미지 1/2 Black and Decker JE2200B Disassembly, Unlocking Latches: 1 단계, 이미지 2/2
    • To undo the locking latches: Pull outwards at the bottom of each latch to detach them from the groove on the cover .
  2. Black and Decker JE2200B Disassembly, Removing the Cover: 2 단계, 이미지 1/2 Black and Decker JE2200B Disassembly, Removing the Cover: 2 단계, 이미지 2/2
    • To remove the cover: Take out the feeder, hold the chute firmly and pull up the cover.
  3. Black and Decker JE2200B Disassembly, Remove Pulp Separator: 3 단계, 이미지 1/1
    • To remove the pulp container: Hold the juice spout with one hand and the back edge of the pulp separator with the other hand. Pull it up while making sure that the cutter/strainer is kept in place
  4. Black and Decker JE2200B Disassembly, Remove Cutter/Strainer: 4 단계, 이미지 1/3 Black and Decker JE2200B Disassembly, Remove Cutter/Strainer: 4 단계, 이미지 2/3 Black and Decker JE2200B Disassembly, Remove Cutter/Strainer: 4 단계, 이미지 3/3
    • To remove the cutter/strainer: Hold the juice spout with one hand and clutch the edge of the cutter/strainer with the other hand; pull it out slowly.
    • ' The teeth on the cutter/strainer are very sharp. '
  5. Black and Decker JE2200B Disassembly, Remove Pulp Container: 5 단계, 이미지 1/1
    • To remove the pulp separator: Hold the sides firmly and pull the container out.
결론
To reassemble your device, follow this guide in reverse order.
Bhavika Shah
회원 가입일: 08/27/15
331 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-5, Blackwell Fall 2015 USF Tampa, Team 5-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S5G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 693
