소개
The motor compartment is located on the bottom of the juicer. In this compartment there are many wires. Make sure the machine is off and unplugged before accessing the compartment. Use caution when working with the wires as electric shock can happen.
필요한 것
To replace the motor compartment, first follow the Disassembly Guide here
이 단계에 사용된 도구:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use the 2.5 mm Flathead adapter to remove the 13.5 mm screws from the bottom of the juicer. The screw head diameter is 5.2 mm.
다른 4명이 해당 안내서를 완성하였습니다.
