주요 콘텐츠로 건너뛰기
Black and Decker JE2200B Saftey Locking Latches Replacement
필요한 것
  1. Black and Decker JE2200B Saftey Locking Latches Replacement, Saftey Locking Latches: 1 단계, 이미지 1/2 Black and Decker JE2200B Saftey Locking Latches Replacement, Saftey Locking Latches: 1 단계, 이미지 2/2
    • Unlock the latches on the juicer by places hands under latches and pulling out.
  2. Black and Decker JE2200B Saftey Locking Latches Replacement: 2 단계, 이미지 1/2 Black and Decker JE2200B Saftey Locking Latches Replacement: 2 단계, 이미지 2/2
    • Grasp the latch close to the juicer with your right thumb and pointer finger and pull to the right.
    • With your other hand, take the plastic opening tool and insert it on the bottom of the latch.
  3. Black and Decker JE2200B Saftey Locking Latches Replacement: 3 단계, 이미지 1/1
    • Push the tool up to remove the latch.
    • Repeat Step 2 for the second safety locking latch.
    • Use gentle force to remove the latches from the juicer to avoid damage to the machine.
결론
다른 2명이 해당 안내서를 완성하였습니다.
AvaAnne Hogue
회원 가입일: 08/27/15
544 평판
안내서 4개 작성하였습니다
USF Tampa, Team 5-5, Blackwell Fall 2015 USF Tampa, Team 5-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S5G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 466
