주요 콘텐츠로 건너뛰기
Black and Decker JS660 Angle Lock Replacement
필요한 것
  1. Black and Decker JS660 Angle Lock Replacement, Base: 1 단계, 이미지 1/2 Black and Decker JS660 Angle Lock Replacement, Base: 1 단계, 이미지 2/2
    • Unscrew the eight screws to open up the jigsaw.
  2. Black and Decker JS660 Angle Lock Replacement: 2 단계, 이미지 1/1
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
  3. Black and Decker JS660 Angle Lock Replacement: 3 단계, 이미지 1/2 Black and Decker JS660 Angle Lock Replacement: 3 단계, 이미지 2/2
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
  4. Black and Decker JS660 Angle Lock Replacement, Angle Lock: 4 단계, 이미지 1/3 Black and Decker JS660 Angle Lock Replacement, Angle Lock: 4 단계, 이미지 2/3 Black and Decker JS660 Angle Lock Replacement, Angle Lock: 4 단계, 이미지 3/3
    • Remove the screw marked and the lever will slide out easily
    • The black screw must next be removed.
    • After removing the screw the lever will slide out of the jigsaw.
결론
Andrew Khouri
회원 가입일: 02/08/16
468 평판
안내서 4개 작성하였습니다
USF Tampa, Team 6-2, Eyestone Spring 2016 USF Tampa, Team 6-2, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 197
