주요 콘텐츠로 건너뛰기
Black and Decker JS660 Blade Holder Replacement
필요한 것
  1. Black and Decker JS660 Blade Holder Replacement, Base: 1 단계, 이미지 1/2 Black and Decker JS660 Blade Holder Replacement, Base: 1 단계, 이미지 2/2
    • Unscrew the eight screws to open up the jigsaw.
  2. Black and Decker JS660 Blade Holder Replacement: 2 단계, 이미지 1/1
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
  3. Black and Decker JS660 Blade Holder Replacement: 3 단계, 이미지 1/2 Black and Decker JS660 Blade Holder Replacement: 3 단계, 이미지 2/2
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
  4. Black and Decker JS660 Blade Holder Replacement, Blade Holder: 4 단계, 이미지 1/2 Black and Decker JS660 Blade Holder Replacement, Blade Holder: 4 단계, 이미지 2/2
    • You will need to take out the entire blade clamp shown.
    • The plastic part is fragile, easy to break
  5. Black and Decker JS660 Blade Holder Replacement: 5 단계, 이미지 1/3 Black and Decker JS660 Blade Holder Replacement: 5 단계, 이미지 2/3 Black and Decker JS660 Blade Holder Replacement: 5 단계, 이미지 3/3
    • Showing the entire blade clamp removed from the device.
    • Apply some oil grease if dry/needed
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Khouri
회원 가입일: 02/08/16
468 평판
안내서 4개 작성하였습니다
USF Tampa, Team 6-2, Eyestone Spring 2016 USF Tampa, Team 6-2, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G2
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
What a great website… I could never have known how to replace the blade holder… Or that I could get the correct parts…I got the replacement part. Then removed the old one, and replaced the new one. NO problem at all.. Thanks to Andrew and this website… With out it, would have to pay some one at a big price, and wait to have it fixed, as would have to send it off for the repair.. Or….. Just throw it away…
Thanks every one… I will share this site for sure…
navy1aedon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 3,389
