주요 콘텐츠로 건너뛰기
Black and Decker JS660 Motor Replacement
필요한 것
  1. Black and Decker JS660 Motor Replacement, Housing Disassembly: 1 단계, 이미지 1/2 Black and Decker JS660 Motor Replacement, Housing Disassembly: 1 단계, 이미지 2/2
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Motor Replacement: 2 단계, 이미지 1/1
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Motor Replacement, Blade Holder: 3 단계, 이미지 1/1
    • Being careful to keep all parts together, grab the entire assembly and pull it directly out of the saw.
  4. Black and Decker JS660 Motor Replacement, Motor: 4 단계, 이미지 1/1
    • Remove the two 30.1625mm screws with a T20 torx screwdriver that are holding the gearbox to the housing.
  5. Black and Decker JS660 Motor Replacement: 5 단계, 이미지 1/1
    • Apply a light force to separate the gearbox from the housing. This will momentarily separate the gearbox and help with the removal of the system in later steps.
  6. Black and Decker JS660 Motor Replacement: 6 단계, 이미지 1/2 Black and Decker JS660 Motor Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers or a small flathead screwdriver, gently remove each of the black magnetic clasps away from the motor.
  7. Black and Decker JS660 Motor Replacement: 7 단계, 이미지 1/1
    • Holding the gearbox and the bering, pull the whole motor and gearbox out of the housing.
  8. Black and Decker JS660 Motor Replacement: 8 단계, 이미지 1/1
    • While holding the motor in one hand, gently pull the gearbox off of the drive shaft.
결론
To reassemble your device, follow these instructions in reverse order. Be careful to line up the gearbox before replacement. The corkscrew end of the motor should be fed through each layer of the gearbox.
Katherine Thomas
회원 가입일: 01/30/17
151 평판
안내서 1개 작성함
Cal Poly, Team 22-9, Maness Winter 2017 Cal Poly, Team 22-9, Maness Winter 2017 회원
CPSU-MANESS-W17S22G9
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 1,198
