주요 콘텐츠로 건너뛰기
Black and Decker JS660 Power Cord Replacement
필요한 것
  1. Black and Decker JS660 Power Cord Replacement, Housing Disassembly: 1 단계, 이미지 1/2 Black and Decker JS660 Power Cord Replacement, Housing Disassembly: 1 단계, 이미지 2/2
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Power Cord Replacement: 2 단계, 이미지 1/1
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Power Cord Replacement, Power Cord: 3 단계, 이미지 1/1
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
  4. Black and Decker JS660 Power Cord Replacement: 4 단계, 이미지 1/1
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
  5. Black and Decker JS660 Power Cord Replacement: 5 단계, 이미지 1/1
    • Gently remove the black and white cord from the trigger assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
matt murray
회원 가입일: 01/27/17
682 평판
안내서 6개 작성하였습니다
Cal Poly, Team 22-9, Maness Winter 2017 Cal Poly, Team 22-9, Maness Winter 2017 회원
CPSU-MANESS-W17S22G9
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 764
