주요 콘텐츠로 건너뛰기
Black and Decker JS660 Trigger Replacement
필요한 것
  1. Black and Decker JS660 Trigger Replacement, Housing Disassembly: 1 단계, 이미지 2개 중 1개 Black and Decker JS660 Trigger Replacement, Housing Disassembly: 1 단계, 이미지 2개 중 2개
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Trigger Replacement: 2 단계, 이미지 1개 중 1개
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Trigger Replacement, Power Cord: 3 단계, 이미지 1개 중 1개
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
  4. Black and Decker JS660 Trigger Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
  5. Black and Decker JS660 Trigger Replacement: 5 단계, 이미지 1개 중 1개
    • Gently remove the black and white cord from the trigger assembly.
  6. Black and Decker JS660 Trigger Replacement, Trigger: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to press down on these tabs on the trigger assembly.
    • While the tab is depressed, the cord can be pulled out of the housing by using a moderate amount of force.
    • Each cord needs to be done separately.
  7. Black and Decker JS660 Trigger Replacement: 7 단계, 이미지 1개 중 1개
    • Remove pink wires from trigger assembly.
결론
작성자
5다른 기여자 명과 함께
matt murray
회원 가입일: 01/27/17
682 평판
안내서 6개를 작성함
Cal Poly, Team 22-9, Maness Winter 2017 Cal Poly, Team 22-9, Maness Winter 2017 회원
CPSU-MANESS-W17S22G9
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 1,615
