주요 콘텐츠로 건너뛰기
Black and Decker LDX 120C Chuck Replacement
필요한 것
  1. Black and Decker LDX 120C Chuck Replacement, Outer Case: 1 단계, 이미지 1/1
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Chuck Replacement: 2 단계, 이미지 1/1
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Chuck Replacement: 3 단계, 이미지 1/1
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Chuck Replacement: 4 단계, 이미지 1/1
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Chuck Replacement: 5 단계, 이미지 1/1
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Chuck Replacement: 6 단계, 이미지 1/1
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Chuck Replacement: 7 단계, 이미지 1/1
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Chuck Replacement, Chuck: 8 단계, 이미지 1/1
    • After following the prerequisite, the drill is now open.
    • The interior components can now be accessed.
  9. Black and Decker LDX 120C Chuck Replacement: 9 단계, 이미지 1/1
    • Separate the top part(the chuck and motor) from the rest of the drill.
  10. Black and Decker LDX 120C Chuck Replacement: 10 단계, 이미지 1/1
    • While separating the top from the rest, do this carefully without over stretching the wires so that no connection is damaged.
  11. Black and Decker LDX 120C Chuck Replacement: 11 단계, 이미지 1/1
    • To remove the motor simply twist as illustrated in the picture.
  12. Black and Decker LDX 120C Chuck Replacement: 12 단계, 이미지 1/1
    • The three metal tips in the front are the ones that are controlled by the chuck to hold and release the screw.
  13. Black and Decker LDX 120C Chuck Replacement: 13 단계, 이미지 1/1
    • To test the chuck twist the head as shown in the illustration.
    • If the three metal tips don't move upon twisting then the chuck isn't working effectively and will need to be replaced since the inside of the chuck can't be accessed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
jeffrey zakka
회원 가입일: 02/09/16
735 평판
안내서 6개 작성하였습니다
USF Tampa, Team 11-5, Cheng Spring 2016 USF Tampa, Team 11-5, Cheng Spring 2016 회원
USFT-CHENG-S16S11G5
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 29
전체 시간: 2,759
