주요 콘텐츠로 건너뛰기
Black and Decker LDX172C Battery Charge Port Replacement
필요한 것
  1. Black and Decker LDX172C Battery Charge Port Replacement, Battery Charge Port: 1 단계, 이미지 1/1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Battery Charge Port Replacement: 2 단계, 이미지 1/1
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Battery Charge Port Replacement: 3 단계, 이미지 1/1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the battery charging port in the base of the drill.
  4. Black and Decker LDX172C Battery Charge Port Replacement: 4 단계, 이미지 1/1
    • Remember that the battery may still have a charge. To avoid electrical shock, it is a good idea to disconnect the battery before modifying any connections on the charging port. You can find how to disconnect the battery here
    • Remove the soldered wire connections as marked.
    • Re-solder the wire connections to the new charge port and insert the charge port back into its proper location.
    • Repeat steps in reverse to reassemble.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eric Miessen
회원 가입일: 02/13/16
182 평판
안내서 1개 작성함
IUPUI, Team 3-3, Wilson Spring 2016 IUPUI, Team 3-3, Wilson Spring 2016 회원
IUPUI-WILSON-S16S3G3
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Hi where can I get the replacement charge port from. Thanks
adam mellor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 39
전체 시간: 2,490
