주요 콘텐츠로 건너뛰기
Black and Decker LDX172C LED Power Indicator Replacement
필요한 것
  1. Black and Decker LDX172C LED Power Indicator Replacement, LED Power Indicator: 1 단계, 이미지 1/1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C LED Power Indicator Replacement: 2 단계, 이미지 1/1
    • Rotate the drill to it's left side - the chuck should be facing rightward. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C LED Power Indicator Replacement: 3 단계, 이미지 1/1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the LED power indicator located just above the battery pack.
  4. Black and Decker LDX172C LED Power Indicator Replacement: 4 단계, 이미지 1/2 Black and Decker LDX172C LED Power Indicator Replacement: 4 단계, 이미지 2/2
    • The LED is located on a small surface mount circuit board that easily slides out of its mounting location.
    • The LED is removed by freeing the solder joints on the bottom side of the circuit board.
    • Place the new LED through the same holes and re-solder it.
    • To reassemble repeat directions in reverse order.
결론
Casey
회원 가입일: 02/13/16
260 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-3, Wilson Spring 2016 IUPUI, Team 3-3, Wilson Spring 2016 회원
IUPUI-WILSON-S16S3G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 205
