주요 콘텐츠로 건너뛰기
Black and Decker LDX172C Trigger Switch Replacement
필요한 것
  1. Black and Decker LDX172C Trigger Switch Replacement, Trigger Switch: 1 단계, 이미지 1개 중 1개
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Trigger Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Trigger Switch Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
  4. Black and Decker LDX172C Trigger Switch Replacement: 4 단계, 이미지 3개 중 1개 Black and Decker LDX172C Trigger Switch Replacement: 4 단계, 이미지 3개 중 2개 Black and Decker LDX172C Trigger Switch Replacement: 4 단계, 이미지 3개 중 3개
    • Remove trigger from drill by pulling the mechanism directly up off the holding pins.
    • The leads from the switch are removed by using a heating the solder until they come free.
    • Re-solder the leads to the new switch.
    • Repeat directions in reverse to reassemble.
결론
작성자
6다른 기여자 명과 함께
jakebontragersinger
회원 가입일: 02/13/16
173 평판
안내서 1개를 작성함
IUPUI, Team 3-3, Wilson Spring 2016 IUPUI, Team 3-3, Wilson Spring 2016 회원
IUPUI-WILSON-S16S3G3
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 3,785
