주요 콘텐츠로 건너뛰기
Black and Decker LI2000 Battery Replacement
필요한 것
  1. Black and Decker LI2000 Battery Replacement, Orange Casing: 1 단계, 이미지 1/3 Black and Decker LI2000 Battery Replacement, Orange Casing: 1 단계, 이미지 2/3 Black and Decker LI2000 Battery Replacement, Orange Casing: 1 단계, 이미지 3/3
    • Remove the following five screws
    • Three 20 mm Phillips #1 screws
    • One 10 mm #000 Phillips screw
    • One 13 mm Phillips 31 screw
    • When you remove the 13 mm screw, the spring may pop out of the screwdriver. Point the backside of the screwdriver away from your face and others.
  2. Black and Decker LI2000 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the black sticker with recycling information.
  3. Black and Decker LI2000 Battery Replacement: 3 단계, 이미지 1/1
    • Use your fingers or a plastic opening tool to pry the casing apart.
  4. Black and Decker LI2000 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the plastic slider by picking it up off the screwdriver.
    • You may consider leaving half of the casing on the screwdriver to make handling the screwdriver easier.
  5. Black and Decker LI2000 Battery Replacement, Handle: 5 단계, 이미지 1/2 Black and Decker LI2000 Battery Replacement, Handle: 5 단계, 이미지 2/2
    • Remove the four 15mm Phillips #1 screws.
  6. Black and Decker LI2000 Battery Replacement: 6 단계, 이미지 1/2 Black and Decker LI2000 Battery Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to pry the casing apart.
  7. Black and Decker LI2000 Battery Replacement, Battery: 7 단계, 이미지 1/2 Black and Decker LI2000 Battery Replacement, Battery: 7 단계, 이미지 2/2
    • Using pliers or your fingers, remove the leads off of the battery.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Katherine Simmons
회원 가입일: 02/08/16
732 평판
안내서 5개 작성하였습니다
IUPUI, Team 1-3, Baechle Spring 2016 IUPUI, Team 1-3, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 3개
It would be great is you could discuss the 3.6v cell - Lithium Type -- Size? Is it an 18650?
William Tzouris - 답글
OK, so where can we get the battery!?
Mike Young - 답글
Check eBay for the 18650 with solder tabs already attached. I purchased a 4 pack of the batteries and used 1 for a LI3100. I needed a Dremel tool to remove some of the internal plastic battery supports to accommodate this battery. If the solder tabs had been oriented 180 degrees to each other, it would have been a drop in fit. Screwdriver works great now!
Jeff McDermaid - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 64
전체 시간: 9,031
