주요 콘텐츠로 건너뛰기
Black and Decker LI2000 Charging Port Replacement
필요한 것
  1. Black and Decker LI2000 Charging Port Replacement, Orange Casing: 1 단계, 이미지 1/3 Black and Decker LI2000 Charging Port Replacement, Orange Casing: 1 단계, 이미지 2/3 Black and Decker LI2000 Charging Port Replacement, Orange Casing: 1 단계, 이미지 3/3
    • Remove the following five screws
    • Three 20 mm Phillips #1 screws
    • One 10 mm #000 Phillips screw
    • One 13 mm Phillips 31 screw
    • When you remove the 13 mm screw, the spring may pop out of the screwdriver. Point the backside of the screwdriver away from your face and others.
  2. Black and Decker LI2000 Charging Port Replacement: 2 단계, 이미지 1/1
    • Remove the black sticker with recycling information.
  3. Black and Decker LI2000 Charging Port Replacement: 3 단계, 이미지 1/1
    • Use your fingers or a plastic opening tool to pry the casing apart.
  4. Black and Decker LI2000 Charging Port Replacement: 4 단계, 이미지 1/1
    • Remove the plastic slider by picking it up off the screwdriver.
    • You may consider leaving half of the casing on the screwdriver to make handling the screwdriver easier.
  5. Black and Decker LI2000 Charging Port Replacement, Handle: 5 단계, 이미지 1/2 Black and Decker LI2000 Charging Port Replacement, Handle: 5 단계, 이미지 2/2
    • Remove the four 15mm Phillips #1 screws.
  6. Black and Decker LI2000 Charging Port Replacement: 6 단계, 이미지 1/2 Black and Decker LI2000 Charging Port Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to pry the casing apart.
  7. Black and Decker LI2000 Charging Port Replacement, Charging Port: 7 단계, 이미지 1/1
    • Pull the charging port and circuit board away from the casing.
  8. Black and Decker LI2000 Charging Port Replacement: 8 단계, 이미지 1/1
    • Refer to the Soldering Technique Guide to remove the wires at the charging port by heating the existing solder on the contacts.
    • Be sure to keep track of which wire was attached to each lead.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katherine Simmons
회원 가입일: 02/08/16
732 평판
안내서 5개 작성하였습니다
IUPUI, Team 1-3, Baechle Spring 2016 IUPUI, Team 1-3, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 11
전체 시간: 545
