소개
Once you have removed the exterior casing, this guide will show you how to remove and replace the lithium-ion battery in your LI4000.
필요한 것
Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
다른 17명이 해당 안내서를 완성하였습니다.
댓글 5개
Anyone know what type of battery this is so I can replace it?
Thanks
Brian
Brian Wong - 답글
If you peel off the paper of the battery, you will find out that it is a 18650 Lithium battery. Mine has US18650VT T11250 label. It seems from SONY.
River Seow - 답글
When looking for a replacement battery, see if you can find one with solder tabs opposite to each other. The internal plastic housing of the battery is made exactly for two tabs opposing each other; I had to cut the plastic here and there to make my battery (with both tabs at the same side) fit.
New one is cheaper than a new battery
