주요 콘텐츠로 건너뛰기
Black and Decker LI4000 Battery Replacement
필요한 것
  1. Black and Decker LI4000 Battery Replacement, Outer Casing: 1 단계, 이미지 1/3 Black and Decker LI4000 Battery Replacement, Outer Casing: 1 단계, 이미지 2/3 Black and Decker LI4000 Battery Replacement, Outer Casing: 1 단계, 이미지 3/3
    • Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
  2. Black and Decker LI4000 Battery Replacement: 2 단계, 이미지 1/1
    • Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
  3. Black and Decker LI4000 Battery Replacement: 3 단계, 이미지 1/2 Black and Decker LI4000 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
  4. Black and Decker LI4000 Battery Replacement: 4 단계, 이미지 1/2 Black and Decker LI4000 Battery Replacement: 4 단계, 이미지 2/2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry on the seam as shown with a Spudger, in order to get the top casing loose.
    • Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
    • It is good practice to remove the top connection of the battery as shown in the third image, as this will be the first step to replacing any of the components for this screwdriver.
  5. Black and Decker LI4000 Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Locate the battery. The cardboard covered cylinder is the rechargeable battery.
  6. Black and Decker LI4000 Battery Replacement: 6 단계, 이미지 1/2 Black and Decker LI4000 Battery Replacement: 6 단계, 이미지 2/2
    • Detach the contact by pulling the contact away from the battery.
  7. Black and Decker LI4000 Battery Replacement: 7 단계, 이미지 1/2 Black and Decker LI4000 Battery Replacement: 7 단계, 이미지 2/2
    • Gently lift the end of the battery out of the plastic casing
  8. Black and Decker LI4000 Battery Replacement: 8 단계, 이미지 1/1
    • Locate the other contact on the rear side of the battery.
  9. Black and Decker LI4000 Battery Replacement: 9 단계, 이미지 1/2 Black and Decker LI4000 Battery Replacement: 9 단계, 이미지 2/2
  10. Black and Decker LI4000 Battery Replacement: 10 단계, 이미지 1/1
    • To install a new battery, repeat the steps in reverse order with a new battery.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Nicholas Kniola
회원 가입일: 02/11/16
527 평판
안내서 1개 작성함
IUPUI, Team 2-3, Baechle Spring 2016 IUPUI, Team 2-3, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S2G3
3 회원들
안내서 8개 작성하였습니다
댓글 5개
Anyone know what type of battery this is so I can replace it?
Thanks
Brian
Brian Wong - 답글
If you peel off the paper of the battery, you will find out that it is a 18650 Lithium battery. Mine has US18650VT T11250 label. It seems from SONY.
River Seow - 답글
When looking for a replacement battery, see if you can find one with solder tabs opposite to each other. The internal plastic housing of the battery is made exactly for two tabs opposing each other; I had to cut the plastic here and there to make my battery (with both tabs at the same side) fit.
Xian Lu - 답글
New one is cheaper than a new battery
Wolfie Shay - 답글
new battery costs 10$, its a 18650 or LI4000
GEEnius - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 15
30일 전: 106
전체 시간: 11,159
