주요 콘텐츠로 건너뛰기
Black and Decker LI4000 Outer Casing Replacement
필요한 것
  1. Black and Decker LI4000 Outer Casing Replacement, Outer Casing: 1 단계, 이미지 1/3 Black and Decker LI4000 Outer Casing Replacement, Outer Casing: 1 단계, 이미지 2/3 Black and Decker LI4000 Outer Casing Replacement, Outer Casing: 1 단계, 이미지 3/3
    • Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
  2. Black and Decker LI4000 Outer Casing Replacement: 2 단계, 이미지 1/1
    • Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
  3. Black and Decker LI4000 Outer Casing Replacement: 3 단계, 이미지 1/2 Black and Decker LI4000 Outer Casing Replacement: 3 단계, 이미지 2/2
    • Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
  4. Black and Decker LI4000 Outer Casing Replacement: 4 단계, 이미지 1/2 Black and Decker LI4000 Outer Casing Replacement: 4 단계, 이미지 2/2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry on the seam as shown with a Spudger, in order to get the top casing loose.
    • Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
    • It is good practice to remove the top connection of the battery as shown in the third image, as this will be the first step to replacing any of the components for this screwdriver.
결론
Bryan Beard
회원 가입일: 02/11/16
107 평판
안내서 1개 작성함
IUPUI, Team 2-3, Baechle Spring 2016 IUPUI, Team 2-3, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S2G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 312
