주요 콘텐츠로 건너뛰기
Black and Decker One Step Steam Iron Temperature Regulator Replacement
필요한 것
  1. Black and Decker One Step Steam Iron Temperature Regulator Replacement, Temperature Regulator: 1 단계, 이미지 1/2 Black and Decker One Step Steam Iron Temperature Regulator Replacement, Temperature Regulator: 1 단계, 이미지 2/2
    • Use a spudger to pry the three screw covers out of the iron.
    • Using force to remove the caps may be necessary. Do not worry if you hear popping sounds when removing them.
  2. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 2 단계, 이미지 1/1
    • Remove the three screws using a T5 Torx screwdriver.
  3. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 3 단계, 이미지 1/1
    • Pull the back cover off.
  4. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 4 단계, 이미지 1/2 Black and Decker One Step Steam Iron Temperature Regulator Replacement: 4 단계, 이미지 2/2
    • Use a spudger to remove the clear rubber cover from the front of the iron.
  5. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 5 단계, 이미지 1/1
    • Remove the single screw located under the rubber cover using a Phillips #0 screwdriver.
  6. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 6 단계, 이미지 1/1
    • Remove the two screws holding the handle to the base using a Phillips #0 screwdriver.
  7. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 7 단계, 이미지 1/1
    • Remove the screws holding the plate to the base using a Phillips #0 screwdriver.
  8. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 8 단계, 이미지 1/3 Black and Decker One Step Steam Iron Temperature Regulator Replacement: 8 단계, 이미지 2/3 Black and Decker One Step Steam Iron Temperature Regulator Replacement: 8 단계, 이미지 3/3
    • Insert a spudger into the space in front of the pumps.
    • Pull down on the spudger so that the tab is visible.
    • Repeat for the other pump.
  9. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 9 단계, 이미지 1/1
    • Remove the two screws using a Phillips #0 screwdriver.
  10. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 10 단계, 이미지 1/1
    • Push the spray nozzle using the pointed end of a spudger.
  11. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 11 단계, 이미지 1/1
    • Remove the handle from the base.
  12. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 12 단계, 이미지 1/1
    • Remove the two pumps.
  13. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 13 단계, 이미지 1/2 Black and Decker One Step Steam Iron Temperature Regulator Replacement: 13 단계, 이미지 2/2
    • Pry the white plastic cylinder out from its hole using a spudger.
    • The plastic cylinder is held in place by the plastic arm. Some force will be necessary.
  14. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 14 단계, 이미지 1/2 Black and Decker One Step Steam Iron Temperature Regulator Replacement: 14 단계, 이미지 2/2
    • Using two spudger, pry the two plastic pieces holding the lever away from the lever.
    • Lift the lever out.
  15. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 15 단계, 이미지 1/1
    • Pull the lever and its attached pump out of the base.
  16. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 16 단계, 이미지 1/1
  17. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 17 단계, 이미지 1/1
    • Insert a spudger in between the white plastic and the purple plastic.
  18. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 18 단계, 이미지 1/1
    • Rotate the spudger so that it separates the top of the white plastic from the bottom of the purple plastic.
  19. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 19 단계, 이미지 1/1
    • Move the spudger along the gap until you hear a popping noise.
  20. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 20 단계, 이미지 1/1
    • Verify that the tab is detached.
  21. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 21 단계, 이미지 1/2 Black and Decker One Step Steam Iron Temperature Regulator Replacement: 21 단계, 이미지 2/2
    • Separate the white plastic from the bottom purple plastic.
    • Hold the top section (white and purple) steady with one hand.
    • Pull the plate (bottom) section toward the side with the tab shown in Step 20 until the plate is detached.
  22. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 22 단계, 이미지 1/1
    • Use the spudger to gently pop the pump connecter off of the plate.
  23. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 23 단계, 이미지 1/1
    • Remove the three visible screws using a Phillips #0 screwdriver.
  24. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 24 단계, 이미지 1/1
    • Remove the plate holder.
  25. Black and Decker One Step Steam Iron Temperature Regulator Replacement: 25 단계, 이미지 1/1
    • Remove the screw using a Phillips #0 screwdriver.
    • Remove the temperature regulator from the iron.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jaidyn Green
회원 가입일: 09/28/21
439 평판
안내서 1개 작성함
University of North Texas, Team 2-4, Raign Fall 2021 University of North Texas, Team 2-4, Raign Fall 2021 회원
UNT-RAIGN-F21S2G4
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 71
30일 전: 325
전체 시간: 4,735
