주요 콘텐츠로 건너뛰기
Black and Decker PHV1810 Hand Vac Charging Port Replacement
필요한 것
  1. Black and Decker PHV1810 Hand Vac Charging Port Replacement, Nozzle, Filter, and Catch Bowl: 1 단계, 이미지 1/2 Black and Decker PHV1810 Hand Vac Charging Port Replacement, Nozzle, Filter, and Catch Bowl: 1 단계, 이미지 2/2
    • To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
  2. Black and Decker PHV1810 Hand Vac Charging Port Replacement: 2 단계, 이미지 1/2 Black and Decker PHV1810 Hand Vac Charging Port Replacement: 2 단계, 이미지 2/2
    • Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
  3. Black and Decker PHV1810 Hand Vac Charging Port Replacement, Motor: 3 단계, 이미지 1/2 Black and Decker PHV1810 Hand Vac Charging Port Replacement, Motor: 3 단계, 이미지 2/2
    • Remove the three screws.
  4. Black and Decker PHV1810 Hand Vac Charging Port Replacement: 4 단계, 이미지 1/2 Black and Decker PHV1810 Hand Vac Charging Port Replacement: 4 단계, 이미지 2/2
    • Flip the hand vac over and remove two screws.
  5. Black and Decker PHV1810 Hand Vac Charging Port Replacement: 5 단계, 이미지 1/3 Black and Decker PHV1810 Hand Vac Charging Port Replacement: 5 단계, 이미지 2/3 Black and Decker PHV1810 Hand Vac Charging Port Replacement: 5 단계, 이미지 3/3
    • Once you have successfully unscrewed the five screws holding the cover on you should be able to take the cover off.
    • Remove the L-shaped plastic hook.
    • Once the L shaped hook has been removed the motor will easily fall out of place.
    • Once the motor has been removed from its home the two wires that are giving it power can easily be removed by pulling on them carefully.
    • This will then allow for you to replace the motor.
  6. Black and Decker PHV1810 Hand Vac Charging Port Replacement, Battery: 7 단계, 이미지 1/3 Black and Decker PHV1810 Hand Vac Charging Port Replacement, Battery: 7 단계, 이미지 2/3 Black and Decker PHV1810 Hand Vac Charging Port Replacement, Battery: 7 단계, 이미지 3/3
    • Remove the three screws highlighted with red circles.
  7. Black and Decker PHV1810 Hand Vac Charging Port Replacement: 8 단계, 이미지 1/2 Black and Decker PHV1810 Hand Vac Charging Port Replacement: 8 단계, 이미지 2/2
    • Remove the battery by pulling it out of the slot it sits in.
  8. Black and Decker PHV1810 Hand Vac Charging Port Replacement, Charging Port: 9 단계, 이미지 1/3 Black and Decker PHV1810 Hand Vac Charging Port Replacement, Charging Port: 9 단계, 이미지 2/3 Black and Decker PHV1810 Hand Vac Charging Port Replacement, Charging Port: 9 단계, 이미지 3/3
    • To get to the charging port you will need the plastic opening tool.
    • Remove the three screws on the handle of the vacuum.
  9. Black and Decker PHV1810 Hand Vac Charging Port Replacement: 10 단계, 이미지 1/2 Black and Decker PHV1810 Hand Vac Charging Port Replacement: 10 단계, 이미지 2/2
    • Use a plastic opening tool to separate the two pieces of plastic.
  10. Black and Decker PHV1810 Hand Vac Charging Port Replacement: 11 단계, 이미지 1/1
    • Remove the plastic covering to the port.
    • Remove the wires to replace the charging port.
결론
Nicholas marsoobian
회원 가입일: 09/24/18
480 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 865
