소개
This guide will show you how to replace the motor on the Black and Decker PS1800.
필요한 것
Lay the drill on its side, assuring that the screw holes are facing upwards.
Remove seven 12 mm screws using a Phillips #00 screwdriver.
Locate the motor at the top left hand corner.
Carefully disconnect the red and black wires attached to the motor.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
