주요 콘텐츠로 건너뛰기
Black and Decker PVH1810 Hand Vac Battery Replacement
필요한 것
  1. Black and Decker PVH1810 Hand Vac Battery Replacement, Nozzle, Filter, and Catch Bowl: 1 단계, 이미지 2개 중 1개 Black and Decker PVH1810 Hand Vac Battery Replacement, Nozzle, Filter, and Catch Bowl: 1 단계, 이미지 2개 중 2개
    • To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
  2. Black and Decker PVH1810 Hand Vac Battery Replacement: 2 단계, 이미지 2개 중 1개 Black and Decker PVH1810 Hand Vac Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
  3. Black and Decker PVH1810 Hand Vac Battery Replacement, Motor: 3 단계, 이미지 2개 중 1개 Black and Decker PVH1810 Hand Vac Battery Replacement, Motor: 3 단계, 이미지 2개 중 2개
    • Remove the three screws displayed in the image.
  4. Black and Decker PVH1810 Hand Vac Battery Replacement: 4 단계, 이미지 2개 중 1개 Black and Decker PVH1810 Hand Vac Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Turn the vacuum around until you see the company logo. Once we are there remove the two screws on the vacuum.
  5. Black and Decker PVH1810 Hand Vac Battery Replacement: 5 단계, 이미지 3개 중 1개 Black and Decker PVH1810 Hand Vac Battery Replacement: 5 단계, 이미지 3개 중 2개 Black and Decker PVH1810 Hand Vac Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Once all screws are removed the casing of the vacuum can be removed.
    • Remove the L-shaped plastic hook.
    • Once the L shaped hook has been removed the motor will easily fall out of place.
  6. Black and Decker PVH1810 Hand Vac Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect any wires or components attached to the motor by gently unplugging them. Remove the motor by unscrewing or unclipping it from the casing
    • This will then allow for you to replace the motor.
  7. Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: 7 단계, 이미지 3개 중 1개 Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: 7 단계, 이미지 3개 중 2개 Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: 7 단계, 이미지 3개 중 3개
    • Remove the three screws highlighted with red circles.
  8. Black and Decker PVH1810 Hand Vac Battery Replacement: 8 단계, 이미지 2개 중 1개 Black and Decker PVH1810 Hand Vac Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the battery by pulling it out of the slot it sits in.
결론
다른 7명이 해당 안내서를 완성하였습니다.
14가이드 댓글
Where can I get a replacement battery?
Lisa - 답글
Anyone? Good place to order a replacement?
Brad - 답글
“Remove the battery” sounds pretty simple, but my pivot vac seems to be “hard-connected” to the battery terminal, and I haven’t a clue where to go from here (though the trash heap—and recycling center—are strong candidates). Mine is an older model (2012) and perhaps that explains why these otherwise excellent instructions lead me to a dead-end.
Jim 4/14/21
James Bonner - 답글
Agree. I dissembled down to this last photo, but the battery won’t budge.
MJ Waz - 답글
the gray handle on one side pops open if you pry at it and there are screws underneath.
Matt Whats -
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 22
지난 30일: 136
전체 시간: 9,045
