주요 콘텐츠로 건너뛰기
Black and Decker PVH1810 Hand Vac Battery Replacement
필요한 것
  1. Black and Decker PVH1810 Hand Vac Battery Replacement, Nozzle, Filter, and Catch Bowl: 1 단계, 이미지 1/2 Black and Decker PVH1810 Hand Vac Battery Replacement, Nozzle, Filter, and Catch Bowl: 1 단계, 이미지 2/2
    • To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
  2. Black and Decker PVH1810 Hand Vac Battery Replacement: 2 단계, 이미지 1/2 Black and Decker PVH1810 Hand Vac Battery Replacement: 2 단계, 이미지 2/2
    • Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
  3. Black and Decker PVH1810 Hand Vac Battery Replacement, Motor: 3 단계, 이미지 1/2 Black and Decker PVH1810 Hand Vac Battery Replacement, Motor: 3 단계, 이미지 2/2
    • Remove the three screws.
  4. Black and Decker PVH1810 Hand Vac Battery Replacement: 4 단계, 이미지 1/2 Black and Decker PVH1810 Hand Vac Battery Replacement: 4 단계, 이미지 2/2
    • Flip the hand vac over and remove two screws.
  5. Black and Decker PVH1810 Hand Vac Battery Replacement: 5 단계, 이미지 1/3 Black and Decker PVH1810 Hand Vac Battery Replacement: 5 단계, 이미지 2/3 Black and Decker PVH1810 Hand Vac Battery Replacement: 5 단계, 이미지 3/3
    • Once you have successfully unscrewed the five screws holding the cover on you should be able to take the cover off.
    • Remove the L-shaped plastic hook.
    • Once the L shaped hook has been removed the motor will easily fall out of place.
    • Once the motor has been removed from its home the two wires that are giving it power can easily be removed by pulling on them carefully.
    • This will then allow for you to replace the motor.
  6. Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: 7 단계, 이미지 1/3 Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: 7 단계, 이미지 2/3 Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: 7 단계, 이미지 3/3
    • Remove the three screws highlighted with red circles.
  7. Black and Decker PVH1810 Hand Vac Battery Replacement: 8 단계, 이미지 1/2 Black and Decker PVH1810 Hand Vac Battery Replacement: 8 단계, 이미지 2/2
    • Remove the battery by pulling it out of the slot it sits in.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Nicholas marsoobian
회원 가입일: 09/24/18
480 평판
안내서 3개 작성하였습니다
댓글 12개
Where can I get a replacement battery?
Lisa - 답글
Anyone? Good place to order a replacement?
Brad - 답글
“Remove the battery” sounds pretty simple, but my pivot vac seems to be “hard-connected” to the battery terminal, and I haven’t a clue where to go from here (though the trash heap—and recycling center—are strong candidates). Mine is an older model (2012) and perhaps that explains why these otherwise excellent instructions lead me to a dead-end.
Jim 4/14/21
James Bonner - 답글
Agree. I dissembled down to this last photo, but the battery won’t budge.
MJ Waz - 답글
the gray handle on one side pops open if you pry at it and there are screws underneath.
Matt Whats -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 33
30일 전: 142
전체 시간: 6,729
