주요 콘텐츠로 건너뛰기
Black and Decker Pivot MAX Battery Replacement
필요한 것
  1. Black and Decker Pivot MAX Battery Replacement, Battery: 1 단계, 이미지 1/2 Black and Decker Pivot MAX Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Battery Replacement: 2 단계, 이미지 1/1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Battery Replacement: 3 단계, 이미지 1/1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Battery Replacement: 5 단계, 이미지 1/1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
결론
다른 25명이 해당 안내서를 완성하였습니다.
Jesse Sipes
회원 가입일: 11/06/17
586 평판
안내서 2개 작성하였습니다
IUPUI, Team S5-G6, Baechle Fall 2017 IUPUI, Team S5-G6, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S5G6
3 회원들
안내서 5개 작성하였습니다
댓글 27개
any idea where to find the replacement battery? Does it come as a unit or do you need to disassemble the battery pack and replace the cells?
DMcDermott - 답글
Where do I get the cells to replace the old ones?
Patricia Leat - 답글
How do you disconnect the quick connect
DJ SmashBeatz - 답글
My battery pack is soldered to a circuit board. There is no quick connect. (Model BDH2000PL, Type 2).
HBL - 답글
Same here. Worst design ever.
James Watson -
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 128
30일 전: 720
전체 시간: 44,728
