주요 콘텐츠로 건너뛰기
Black and Decker Pivot Plus PD600 Battery Replacement
필요한 것
  1. Black and Decker Pivot Plus PD600 Battery Replacement, Drill: 1 단계, 이미지 1/3 Black and Decker Pivot Plus PD600 Battery Replacement, Drill: 1 단계, 이미지 2/3 Black and Decker Pivot Plus PD600 Battery Replacement, Drill: 1 단계, 이미지 3/3
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 Battery Replacement: 2 단계, 이미지 1/1
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  3. Black and Decker Pivot Plus PD600 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Locate the battery and remove it from its slot at the end of the drill opposite the motor. It should be at the butt of the drill by the handle.
  4. Black and Decker Pivot Plus PD600 Battery Replacement: 4 단계, 이미지 1/1
    • Unplug the battery by pulling out both the red and black wires. They should come out easily with a little bit of force.
    • But be careful not to disconnect the wire from the metal it is attached to. In order to avoid this, pull the wire out by holding on to the metal part instead of just the wire.
  5. Black and Decker Pivot Plus PD600 Battery Replacement: 5 단계, 이미지 1/1
    • Now take the replacement battery and slide the metal parts of the wire into the metal part of the battery.
    • Make sure that the red wire connects to the curved end of the battery, and that the black wire connects to the straight end of the battery.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Jonathon Centofranchi
회원 가입일: 04/19/13
307 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013 회원
CPSU-MANESS-S13S4G15
5 회원들
안내서 6개 작성하였습니다
댓글 9개
this drill adapter, why "6V" and the adapter body is marked 9VAC output? which is true output?
Can someone test the output and tell me the voltage? VDC? VAC? thankyou.
u411323 - 답글
Unfortunately I do not own the drill anymore so I can't test its output. I do know that the battery used is 6V, so I would assume that is the output. Hopes this helps!
Jonathon Centofranchi - 답글
Where can I buy the replacement battery pack for less than replacing the tool?
shgarceau - 답글
Well, I just checked B & D's web site and can buy a battery pack for $17.95 PLUS $10.99 shipping (cheapest offered).
I think buying a new one is a better idea.
shgarceau - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 29
30일 전: 131
전체 시간: 28,197
