소개
If your drill stops working and the battery stops holding a charge chances are you need a new battery. You can find a replacement parts including the battery under the replacement part links in the device page. This guide will show you how to install this new battery.
필요한 것
Remove the nine 15mm Philips #1 screws
Remove the two 12.5mm Philips #1 screws
Remove the two 10mm Philips #1 screws
Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
Locate the battery and remove it from its slot at the end of the drill opposite the motor. It should be at the butt of the drill by the handle.
B+D sell the replacement for ~$17
I don't know what type of batteries are used in this drill, but you can buy them by clicking on the link entitled Black and Decker Pivot Plus PD600 Replacement Parts on the main page, or by using the below
1. What if you discover broken wires at the solder joints on the circuit board? 2. Which part of the charger connector is + and -? (The pin, or the shield?) Miike Smith 8/19/2021
Is there a schematic for the circuit board available?
Now take the replacement battery and slide the metal parts of the wire into the metal part of the battery.
The battery replacement pack is nearly as expensive as a new drill and seemingly unavailable (universally marked for backorder), making this impractical for two reasons. Can someone who has replaced the battery pack disassemble it so we can see what components it’s made of? It may be easier to rebuild the battery pack from individual components rather than to order a stock one.
Also, the wires from the PCB connected to the motor are on the other side of the joint (where the drill bends), making the connections susceptible to metal fatigue. The black wire attached to the motor on my drill broke free from years of switching the joint from straight to charge and bent to use. I fixed it with scrap wire, cable ties, and a hot glue gun to ensure it never happens again.
Very disappointed in this product!!!
다른 9명이 해당 안내서를 완성하였습니다.
댓글 9개
this drill adapter, why "6V" and the adapter body is marked 9VAC output? which is true output?
Can someone test the output and tell me the voltage? VDC? VAC? thankyou.
Unfortunately I do not own the drill anymore so I can't test its output. I do know that the battery used is 6V, so I would assume that is the output. Hopes this helps!
Garbage product ??????
Where do I order the replacement battery
