주요 콘텐츠로 건너뛰기
Black and Decker Pivot Plus PD600 LED light Replacement
필요한 것
  1. Black and Decker Pivot Plus PD600 LED light Replacement, Drill: 1 단계, 이미지 1/3 Black and Decker Pivot Plus PD600 LED light Replacement, Drill: 1 단계, 이미지 2/3 Black and Decker Pivot Plus PD600 LED light Replacement, Drill: 1 단계, 이미지 3/3
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 LED light Replacement: 2 단계, 이미지 1/1
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  3. Black and Decker Pivot Plus PD600 LED light Replacement, LED light: 3 단계, 이미지 1/1
    • In order to replace the small LED light look below the motor at the front of the drill to find a black plastic piece with two very skinny wires emanating from it.
    • The black plastic piece is the housing. The light is placed inside this black plastic housing.
  4. Black and Decker Pivot Plus PD600 LED light Replacement: 4 단계, 이미지 1/1
    • Pull the black plastic piece up out of the slot in the drill body that it fits into.
  5. Black and Decker Pivot Plus PD600 LED light Replacement: 5 단계, 이미지 1/1
    • The light itself can be easily removed from the black plastic piece by simply pulling it out.
    • One of the metal “legs” on the LED is longer than the other and it must be placed in the black plastic housing in the same manner it was removed or it will not work.
  6. Black and Decker Pivot Plus PD600 LED light Replacement: 6 단계, 이미지 1/1
    • Take your new LED and slide it back into the plastic housing in the same orientation as the old LED.
결론
다른 2명이 해당 안내서를 완성하였습니다.
justin boyd
회원 가입일: 05/13/13
131 평판
안내서 1개 작성함
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013 회원
CPSU-MANESS-S13S4G15
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 12
전체 시간: 792
