소개
If the LED light in the drill no longer turns on, you can use this guide to easily replace it with a new one.
필요한 것
Remove the nine 15mm Philips #1 screws
Remove the two 12.5mm Philips #1 screws
Remove the two 10mm Philips #1 screws
In order to replace the small LED light look below the motor at the front of the drill to find a black plastic piece with two very skinny wires emanating from it.
The black plastic piece is the housing. The light is placed inside this black plastic housing.
다른 2명이 해당 안내서를 완성하였습니다.
