주요 콘텐츠로 건너뛰기
Black and Decker Pivot Plus PD600 Motor Replacement
필요한 것
  1. Black and Decker Pivot Plus PD600 Motor Replacement, Drill: 1 단계, 이미지 1/3 Black and Decker Pivot Plus PD600 Motor Replacement, Drill: 1 단계, 이미지 2/3 Black and Decker Pivot Plus PD600 Motor Replacement, Drill: 1 단계, 이미지 3/3
    • Remove the nine 15mm Philips #1 screws
    • Remove the two 12.5mm Philips #1 screws
    • Remove the two 10mm Philips #1 screws
  2. Black and Decker Pivot Plus PD600 Motor Replacement: 2 단계, 이미지 1/1
    • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  3. Black and Decker Pivot Plus PD600 Motor Replacement, Motor: 3 단계, 이미지 1/1
    • After opening the the casing, locate and grab the head of the drill. Twist the motor counter-clockwise and pull to detach it from the transmission.
    • However, do not pull too hard because the motor is attached to other components of the drill by wires.
  4. Black and Decker Pivot Plus PD600 Motor Replacement: 4 단계, 이미지 1/2 Black and Decker Pivot Plus PD600 Motor Replacement: 4 단계, 이미지 2/2
    • After taking out the motor, you can observe two wires that are plugged in (or possibly soldered, depending on which variant you have) to the bottom of the motor. To detach the motor, unplug the wires or desolder their connections with a soldering iron as needed.
    • Mark or color code the black and red wires so you can return them to the correct position.
  5. Black and Decker Pivot Plus PD600 Motor Replacement: 5 단계, 이미지 1/1
    • Wait for the wires and connectors to cool. Pull the wires from the motor and the motor should now be fully disconnected from the drill.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jonathon Centofranchi
회원 가입일: 04/19/13
307 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013 회원
CPSU-MANESS-S13S4G15
5 회원들
안내서 6개 작성하였습니다
댓글 한 개
If my motor try to turn is there anything I can do to fix-it? :)
Kenny Ray Carder - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 13
전체 시간: 1,316
