소개
If the motor of the drill stops working, this guide will show you how to remove the motor of the black and decker Pivot Plus PD600 whether for repair, or for other use.
필요한 것
Remove the nine 15mm Philips #1 screws
Remove the two 12.5mm Philips #1 screws
Remove the two 10mm Philips #1 screws
After opening the the casing, locate and grab the head of the drill. Twist the motor counter-clockwise and pull to detach it from the transmission.
다른 4명이 해당 안내서를 완성하였습니다.
