소개
The pivot button may need to be installed if problems such as jamming of the button occur. This guide will outline how to install the pivot button on the Black and Decker Pivot Plus PD600.
부품
No parts specified.
  1. Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver. Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver.
    • Remove the screw located on the opposite side of the black half of the button with the lock symbol with the Phillips #1 screwdriver.
  2. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  3. After the screw is removed, take off both sides of the button. You will be left with 3 pieces. Two halves of the button (a black piece with a lock on the front, and a circular orange piece) will be left over along with a spring.
    • After the screw is removed, take off both sides of the button.
    • You will be left with 3 pieces. Two halves of the button (a black piece with a lock on the front, and a circular orange piece) will be left over along with a spring.
결론
Ryan Angelich
회원 가입일: 2013년 05월 13일
101 평판
안내서 1개 작성함
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013 회원
CPSU-MANESS-S13S4G15
5 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 749
