주요 콘텐츠로 건너뛰기
Black and Decker Pivot Plus PD600 Pivot Button Disassembly
필요한 것
  1. Black and Decker Pivot Plus PD600 Pivot Button Disassembly, Black and Decker Pivot Plus PD600 Pivot Button Disassembly: 1 단계, 이미지 1/2 Black and Decker Pivot Plus PD600 Pivot Button Disassembly, Black and Decker Pivot Plus PD600 Pivot Button Disassembly: 1 단계, 이미지 2/2
    • Locate the pivot button screw labeled with a lock symbol.
    • Remove the screw with a Phillips #1 screwdriver.
  2. Black and Decker Pivot Plus PD600 Pivot Button Disassembly: 2 단계, 이미지 1/2 Black and Decker Pivot Plus PD600 Pivot Button Disassembly: 2 단계, 이미지 2/2
    • Set the screw to the side.
    • Remove both sides of the button from the screwdriver.
    • You will be left with three pieces: a black piece with a lock on the front, a circular orange piece, and a spring.
결론
Ryan Angelich
회원 가입일: 05/13/13
101 평판
안내서 1개 작성함
Cal Poly, Team 4-15, Maness Spring 2013 Cal Poly, Team 4-15, Maness Spring 2013 회원
CPSU-MANESS-S13S4G15
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,131
