주요 콘텐츠로 건너뛰기
Black and Decker TO1303SB, TO1313B Heat Controls Replacement
필요한 것
  1. Black and Decker TO1303SB, TO1313B Heat Controls Replacement, Top Cover: 1 단계, 이미지 1/2 Black and Decker TO1303SB, TO1313B Heat Controls Replacement, Top Cover: 1 단계, 이미지 2/2
    • Remove the six 9.5mm screws on the back panel using a #2 Phillips screwdriver.
  2. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 2 단계, 이미지 1/1
    • Remove the two 13mm screws, located between the feet on the bottom of the cover, using a Torx T15 screw driver.
    • On the TO1313SB, a Security Torx T15 driver is required — the screws have a center pin that prevents use of a regular T15 driver.
  3. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 3 단계, 이미지 1/1
    • Using the metal spudger, carefully pry out the rubber base on each foot to access the screws.
  4. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 4 단계, 이미지 1/1
    • Remove the 11.5 mm screws using a #2 Phillips screwdriver.
  5. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 5 단계, 이미지 1/2 Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 5 단계, 이미지 2/2
    • Remove the back cover by gently pulling the sides of the cover apart from the rest of the oven. Then, tilt the cover towards the face and pull back at an upward angle. The cover should slide right off.
  6. Black and Decker TO1303SB, TO1313B Heat Controls Replacement, Control Knobs: 6 단계, 이미지 1/1
    • Using two metal spudgers, pry the top control knob directly outward.
  7. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 7 단계, 이미지 1/1
    • Using the two metal spudgers, pry the middle control knob directly outward.
  8. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 8 단계, 이미지 1/1
    • Using the two metal spudgers, pry the bottom control knob directly outward.
  9. Black and Decker TO1303SB, TO1313B Heat Controls Replacement, Heat Controls: 9 단계, 이미지 1/1
    • Remove the two 5.5mm screws, that are holding the oven controls to the face, using a #2 Phillips head screwdriver.
  10. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 10 단계, 이미지 1/1
    • Remove the two 7.5mm screws, that hold the toaster controls to the face, using a #2 Phillips head screwdriver.
  11. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 11 단계, 이미지 1/1
    • Remove the two 5.5 mm screws, that hold the timer to the face, using a #2 Phillips head screwdriver.
    • The timer is removed so that the wires that need to be un-clipped from the heat controls are easier to access.
  12. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 12 단계, 이미지 1/2 Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 12 단계, 이미지 2/2
    • Press down the metal tab on the oven heat control connector using needle nose pliers and pull outwards to remove the connector.
  13. Black and Decker TO1303SB, TO1313B Heat Controls Replacement: 13 단계, 이미지 1/1
    • Using your thumb, carefully peel back the heat shielding from the connector on the toast heat control.
    • Press down the metal tab on the connector using needle nose pliers or tweezers.
    • Do not try to peel the heat shielding back too far; it tears easily.
    • Repeat for each of the three connections on the control.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alejandro Martin
회원 가입일: 10/01/15
339 평판
안내서 3개 작성하였습니다
Cal Poly, Team 5-11, Maness Fall 2015 Cal Poly, Team 5-11, Maness Fall 2015 회원
CPSU-MANESS-F15S5G11
4 회원들
안내서 5개 작성하였습니다
댓글 3개
I got to removing the “back” cover. Black cover perhaps? There seem to be silver tabs from the front silver facing that are defeating my attempts to remove the cover.
Joe - 답글
Hi Alejandro, could you tell me how to replace the heating elements. Or maybe just how to access them for better cleaning? Or maybe just suggestions on how to clean them while in place since they do rotate? Vinegar-water isn’t working. Thanks!!!
Ginny Lupo - 답글
Where can I get a new toast/ heater control unit?
Rick P. Weyersberg - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 58
전체 시간: 6,743
