주요 콘텐츠로 건너뛰기
Black and Decker TR1278B Bread Grabber Spring Replacement
필요한 것
  1. Black and Decker TR1278B Bread Grabber Spring Replacement, Top Cover: 1 단계, 이미지 1/1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Bread Grabber Spring Replacement: 2 단계, 이미지 1/1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Bread Grabber Spring Replacement: 3 단계, 이미지 1/1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Bread Grabber Spring Replacement: 4 단계, 이미지 1/1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Bread Grabber Spring Replacement: 5 단계, 이미지 1/1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. Black and Decker TR1278B Bread Grabber Spring Replacement, Bread Grabber Spring: 6 단계, 이미지 1/1
    • Locate the spring
  7. Black and Decker TR1278B Bread Grabber Spring Replacement: 7 단계, 이미지 1/1
    • Press down on the toaster lever to gain access to the grabber spring located behind the large metal plate.
    • Use metal spudger to loosen clamps on spring.
  8. Black and Decker TR1278B Bread Grabber Spring Replacement: 8 단계, 이미지 1/1
    • Use needle nose tweezers to pull the spring off of its hook.
    • Repeat this step for the opposite side.
  9. Black and Decker TR1278B Bread Grabber Spring Replacement: 9 단계, 이미지 1/1
    • Remove the old spring from the toaster unit to insert the new one.
결론
Brea-Monique
회원 가입일: 02/15/17
351 평판
안내서 3개 작성하였습니다
USF Tampa, Team 8-1, Eyestone Spring 2017 USF Tampa, Team 8-1, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 16
전체 시간: 1,191
