소개
Black and Decker TR1278B toaster lever catch-spring replacement guide.
  1. Unplug the toaster before disassembly.
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
  3. Detach the bottom from the front cover using the plastic opening tool.
    • Detach the bottom from the front cover using the plastic opening tool.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Turn the toaster right side up.
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  6. Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  7. Lift the top cover up and remove it from the toaster.
    • Lift the top cover up and remove it from the toaster.
  8. Locate the springs.
    • Locate the springs.
    • There is a top spring and bottom spring.
  9. Use needle nose tweezers to free one end of the spring. Turn the spring until it is completely free.
    • Use needle nose tweezers to free one end of the spring.
    • Turn the spring until it is completely free.
  10. Remove spring for replacement.
    • Remove spring for replacement.
    • Repeat steps for bottom spring.
결론
Brea-Monique
회원 가입일: 2017년 02월 15일
303 평판
안내서 3개 작성하였습니다
USF Tampa, Team 8-1, Eyestone Spring 2017 USF Tampa, Team 8-1, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G1
3 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 19
전체 시간: 365
